13 Mar 2014 at 18:27 #1 Vakas Vakas Associate Joined 8 Apr 2009 Posts 1,880 Location Manchester Hi I am looking for a 27 inch IPS monitor my budget is £280
13 Mar 2014 at 19:27 #2 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester can't decide which one to get. I have chosen these 2 models. http://www.overclockers.co.uk/showproduct.php?prodid=MO-117-IY&groupid=17&catid=1120 http://www.overclockers.co.uk/showproduct.php?prodid=MO-062-AS&groupid=17&catid=1120 Last edited: 13 Mar 2014
13 Mar 2014 at 22:02 #3 3t3P 3t3P Soldato Joined 20 Dec 2006 Posts 3,760 we must shine 'PCM2' and the 'badass' symbols onto the clouds and wait... have you looked at tftcentral and http://pcmonitors.info/
13 Mar 2014 at 22:21 #4 Lartyconshayo Lartyconshayo Soldato Joined 5 Dec 2010 Posts 3,320 Location deep space nine I believe the Asus will more likely be of a superior build quality. If you could stretch the budget I would maybe look at getting a monitor with higher resolution http://www.overclockers.co.uk/showproduct.php?prodid=MO-018-AO&groupid=17&catid=1120
13 Mar 2014 at 23:33 #5 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester I don't really like the Aoc brand had bad experiences in the past they feel a bit flimsy and cheap Last edited: 13 Mar 2014
18 May 2014 at 21:07 #6 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester I have still not purchased a new monitor I like the iiyama as it height adjustable but I can get the Asus for the same price as the Iiyama. So what do you think guys?
18 May 2014 at 22:41 #7 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester Anyone?
19 May 2014 at 00:47 #8 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester Just seen this vey tempted, what do you rekon? http://www.overclockers.co.uk/showproduct.php?prodid=MO-111-LG
19 May 2014 at 01:25 #9 Chives Chives Soldato Joined 17 Dec 2009 Posts 3,664 Location Wales Vakas said: Just seen this vey tempted, what do you rekon? http://www.overclockers.co.uk/showproduct.php?prodid=MO-111-LG Click to expand... Check out the comments here first http://forums.overclockers.co.uk/showthread.php?p=26323299#post26323299
19 May 2014 at 15:42 #10 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester Hmm would have to wait for reviews... See what happens
19 May 2014 at 15:49 #11 snips86x snips86x Soldato Joined 14 Nov 2012 Posts 17,971 Location Chesterfield Vakas said: Just seen this vey tempted, what do you rekon? http://www.overclockers.co.uk/showproduct.php?prodid=MO-111-LG Click to expand... +1 Gets my vote. If it doesn't work out for you, RMA under DSR
22 May 2014 at 17:56 #12 Vakas Vakas Associate OP Joined 8 Apr 2009 Posts 1,880 Location Manchester This is on for £300 now still don't know if I will like the aspect ratio though
