I have just sent back my Sony HT-XT3 after 3 months due to it being stuck in a power on/off loop and if i did work you could only turn the volume up or down and the lip sync issue that sony cant fix.If it worked it was a very good sound base.
So i sent it back to JL now have up to £400 pounds to spend on a sound base/bar.
The tv it will go with is a LG 55UF860V 4K
I am leaning to wards a bar as my tv is wall mounted.I also don't need a curved bar or surround speakers .
The only sticking point is it must come from jl.
Has any one got some good ideals for the above thanks
