Spec me a... paper document storage system... thing
6 Oct 2004
Birmingham
I have a load of papers/documents which need to be stored in an organised manner (mortgage/house documents, work contracts, education certificates, loan agreements, warranties, etc.).
I did have something a bit like this:
http://www.amazon.co.uk/Star-Office...&qid=1417515718&sr=8-26&keywords=storage+file
But unfortunately the number of papers I have has now outgrown it, and it's starting to collapse under its own weight!
Just wondering what you guys use and if you have any recommendations?
A full size filing cabinet is out of the question as I don't have the space :p
I was looking at those metal ones, but they don't seem to be much bigger than the card one I've got (although obviously a lot more robust!)
I guess I could get a couple of box files for the "chunkier" papers, and one of those metal ones for the odd bits.
Why not just buy another one, or two :p
Shush Mr Logic and Reason :p
Yeah, that's always another option, was just wondering if anyone had discovered some hidden gem of document storage which had solved all of the worlds problems and discovered alien life :p
Document scanner* + Cloud Storage + Backups. No need to keep all that paper (clearly you need to keep some paper documetsn mind you)
* Proper one that does duplex not a rubbish flatbed attached to a printer.
