Spec me a PC for ArcGIS
26 Mar 2012
Looking for a PC that will run ArcGIS at a proficient level for my university coursework. I've managed to get a copy of the software for free from my university. I don't want to build the PC myself but I do want to buy from Overclockers as a sort of system configurator build. I'd like the system to be easily upgradeable in the future in terms of adding an additional SSD, RAM and perhaps a better graphics card if needs be. I need a mouse and keyboard as well as an OS. I already have a widescreen monitor sourced. Budget wise I'd like to keep it around the £600 mark.
How about something like this
My basket at Overclockers UK:
  • 1 x OcUK Tech Labs H110 Skylake Home & Small Office Micro ATX PC Configurator = £607.85
    • Case:Fractal Design Core 1000 Micro-ATX Case - Black
    • Power Supply:SuperFlower FX 450W '80 Plus Bronze' Power Supply - Black
    • WIFI:Asus PCE-N15 300Mbps 802.11B/G/N Wireless PCI-E Network Adapter
    • Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
    • Security Software:Unwanted
    • Keyboard & Mouse Set:Unwanted
    • Monitor:Unwanted
    • Headset / Headphones:Unwanted
    • Processor:Intel Core i3-6100 3.70GHz (Skylake) Socket LGA1151 Processor - Retail
    • Memory:Crucial Ballistix Sport 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP8G3D1609DS1S00
    • Motherboard:Asus H110M-Plus D3 Intel H110 (Socket 1151) DDR3 Micro ATX Motherboard
    • Solid State Drive:Samsung 250GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E250B/EU)
    • Mechanical Hard Drive:Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
    • Optical Drive **Please Check Chassis Support**:OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
    • Graphics Card:Sapphire Radeon R7 240 Boost 2048MB GDDR3 PCI-Express Card
Total: £621.95
(includes shipping: £14.10)
Personally I'd get in touch with them on here or by phone, and ask for the Raijintek Arcadia case as it's midi size rather than mATX. Also I wasn't able to but you can ask to take out the wireless card if you won't need it.
Only an i3 processor? I was thinking at minimum an i5. I wanted to go for an i7 but that will exceed my budget by a fair amount. The rest of it looks pretty solid though. Thank you.
