Spec me a Pc for Gaming
12 Jun 2009
Tun. Wells, Kent
I am looking to buy a new computer purely for gaming. I have roughly £850-900 to spend but I'm mostly looking for value for money. I also need an OS, keyboard, mouse, and monitor. I want the monitor to be 24". I am prepared to overclock the graphics card and processor.
Any help much appreciated
Thanks in advance
Wow great spec there...
Personally if i had the money i'd spend a bit more on a better looking case :P
Got nothing against it, it's just not the prettiest case out there ^^
I'm thinking about buying that build, what case would you suggest Tibbz2?
Well for a bit cheaper the Antec 300 or Zalaman Z9 Plus, both @ £50ish
For around the same price some of the other Coolermaster cases (like the Storm Scout, CM-690II Lite, or the Storm Enforcer)
And there are quite a few more expensive nice cases.
If you were looking at the High Air Flow cases though, the 922 or 932 look a bit nicer imo.
thanks tibbz, what do you think of the Antec 100 One Hundred Ultimate Gaming Case - Black in the second build..
Also would you suggest more RAM with the first build? I dont really know much about it all so any advice would be amazing.
Both the Antec 100 and 300 cases are very nice, and have a good rep. It's just a matter of which you prefer the specs and look of ^^
Also 4GB RAM is enough for every game, there is no need to go any higher for gaming atm. However you can easily upgrade with another 4GB kit when needed ;)
Here you go fella
http://www.overclockers.co.uk/showproduct.php?prodid=MY-303-CS
Buy an LED monitor from somewhere else. Dont get the one you put in your shopping list!
There is also another popular computer parts site which we use which i think has better deals at the moment with i5 bundles so you might wanna check that out?
Win 7 HP was going for £50 about a day ago. (Not on here)
Maybe overclockers should check out the competition and reduce their prices!
