No sense going for 120gb when 240gb costs a tiny amount more.
My basket at Overclockers UK:
- 1 x XFX Radeon R9 390 "DD Black Edition" 8192MB GDDR5 PCI-Express Graphics Card (R9-390P-8DB6)= £239.99
- 1 x Microsoft Windows 10 32/64-Bit - USB Pen Drive - Retail (KW9-00017)= £85.99
- 1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black= £59.99
- 1 x Crucial BX200 240GB SSD SATA 6Gbps Solid State Drive (CT240BX200SSD1)= £59.99
- 1 x Raijintek Aidos Direct Contact CPU Cooler - Black= £12.95
- 1 x Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (HX324C11SRK2/8)= £38.99
- 1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving**= £266.98
- 1 x Bitfenix Nova Midi Tower Case - Black= £23.99
Total: £806.99
(includes shipping: £18.12)
Manufacturer states 600w or greater required. I would just be cautious to avoid potential problems as there isnt a great price difference between the two.
You don't need an optical drive to install it. Quicker too
Hello
looks like the case can not handle the heat ?it gets insanely hot, i have to use it with the side off, when it is under load, most of the heat seems to be from the gpu, so can someone spec me something better please, looking at a £60 ish budget, thanks
