spec me a pc please
11 Jan 2007
i have 800 pounds and need 2 gig of ram a mobo and an 8800 graphics card will run at 1400x900 so would 8800 320 mb be enough,
a sata hd (250 gig plus)
a conroe cpu (6300)
a psu supply
game to be run are ut3 ,cryiss,gulid wars and quake wars.
need help on a mobo that runs x16 pci slot and is cheap and i will not be overclocking.
open to all suggestions thanks in advance blue:)
Intel Core 2 DUO E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail
(£111.61)
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU (CMPSU-620HXUK)
(£99.86)
Akasa AK-ZEN-01-BK Zen Black Case - No PSU
(£29.36)
EVGA GeForce 8800 GTS SuperClocked 320MB GDDR3 HDTV/Dual DVI (PCI-
Express) - Retail
(£211.49)
GeIL 2GB (2x1GB) PC6400C5 800MHz Value DDR2 Dual Channel Kit (GX22GB6400DC)
(£99.86)
Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard
(£82.24)
Samsung SH-W183 18x18 DVD±RW Serial ATA Dual Layer ReWriter (Black) - OEM
(£21.14)
Tuniq Tower 120 CPU Cooler
(£35.24)
Hitachi Deskstar T7K500 NCQ 400GB SATA-II 16MB Cache - OEM (0A33439)
(£64.61)
Total : £768.29
PS Overclock, it's easy. Don't be a n00b :D
I will not be overclocking
I said that when I got my Conroe, now I'm sitting at 3GHz. With such a nice setup and a core 2 you will be a fool not to, it only takes a quick nudge of the FSB - I hadn't overclocked before this but got a little assistance from WJA now I won't look back.
Melbourne's spec is good :)
Cheers Dude.
I know Mishima has had a lot of success with that case, and at that price you can't go far wrong.
A friend of mine had a 4300 up to 3.7GHz, admittedly with a great deal of lapping...
Thats a major overclock on a E4300!! Very good. thats impressive.
Yeah I have that case at the moment, its great for the price. I think the best feature is the noise, and airflow when I moved to this case the temperatures dropped quite dramatically and this is a budget case! The build quality isn't fantastic but like I say its a budget case and it suits the needs. Looks very nice too, I have some pics if you want to see blueplayer, just say and I can post.
Total bang for buck that, bet he is well happy with the results. How hot is the chip under that? Mines doing well, only a few more degrees hotter than it was at stock.
It was very hot at 3.7, mainly because there was so many volts going though it. I think at 3.4 it is well under 60 degrees full load, even with low speed on the fans.
