Hi,
It is time for an up grade and rebuild of my PC.
I am looking for almost a complete rebuild and the only items I will be utilising are the Tagen power supply 550 watt, Graphics card, a few 1TB HDD, and PC case.
Spec wise I am hoping to get 16GB of RAM, i7 CPU if I afford it a 4Ghz would be nice, SSD Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive is my fav choice.
http://www.overclockers.co.uk/showproduct.php?prodid=HD-192-SA
As for MoBo I usually go for ASUS brand, though I am open to suggestions.
Budget, well I think I need to spend apx £250-£300 just on the CPU, the SSD Samsung at the moment is £149.99
I mainly use my PC for gaming and digital media manipulation.
Many thanks
T
Many thanks
T
