Spec me a pc pls
10 Sep 2008
Uk
hi, just wondering if someone could spec me a pc for a friend of the family’s son.. the main game he plays is Fortnite so the build needs to be able to play that on high settings .. many thx in advance
Unfortunately not no m8..
That's a seriously tight budget, you might be better off looking at the second hand market or a console.
My basket at OcUK:
Total: £635.92 (includes delivery: £11.98)​
I'd really try to increase the budget to around £800, that way you could move to a more modern platform like AM5 and pop in a better GPU such as a 6700XT. If that's too much of a push, at least another £100 on a 6700XT would still be massively worthwhile, especially given the resolution of your monitor. PSU options on OCUK are sadly very limited at the moment, they used to have a be Quiet! System Power 10 600w for under £40 which is a solid budget option.
My basket at OcUK:
Total: £612.92 (includes delivery: £11.98)​
I'd really try to increase the budget to around £800, that way you could move to a more modern platform like AM5 and pop in a better GPU such as a 6700XT. If that's too much of a push, at least another £50-60 on a 6700XT would still be massively worthwhile, especially given the resolution of your monitor.
Thank you .. really appreciate it.. I’ll see about his budget, if he can increase.. if he can to £800 what changes would be best for the build?
£800 doesn't get you much better, would probably be best spending on a GPU, but that would take you to my list above but with a 7700xt
6700XT's can be had for £280-320 or so, which I would lean towards along with 32gb of RAM instead of 16gb. It'd be that or a modern platform like AM5 but keeping the 7600, which would have better long term prospects for upgrades.
You could also put in an offer for this:
My basket at OcUK:
Total: £323.20 (includes delivery: £3.99)​
I'm sure someone mentioned getting one for close to £200 recently. Just hold in mind that OCUK only offer a 3 month warranty on B grade items.
