HS-015-ZA Zalman CNPS9500-LED Aero Flower (Socket 939/754/478/775) CPU Cooler (HS-015-ZA
MB-046-MS MSI K8N Neo4 Platinum nForce4 Ultra (Socket 939) PCI-Express Motherboard (MB-046-MS)
xirokx said:will you be overclocking? if yes then you will be limited with that mobo
Also what res do you game at?
Monstermunch said:What a load of tosh! The MSI board is nearly as gooder clocker as the DFI Ultra-D
semi-pro waster said:Little bit harsh perchance? Technically it is right, every motherboard(and CPU) has a finite limit to the overclockability
I don't know about the clocking abilities so the MSI might be great, in which case I don't doubt your superior knowledge but I'm just querying if 'tosh' is a tad too dismissive
LMAO.....What a load of tosh!
xirokx said:Also what res do you game at?
xirokx said:rofl
