Spec me a PC
11 Feb 2014
evening,
Long time shopper, 1st time poster so go easy if I've missed anything important off of this post.
Anyway normally I just buy budget PCs from Ebay but this time I'd like to build my own. I just don't really know where to start.
The basic requirements, I'm an Eve Online player and need to be able to run 3 accounts concurrently, I do this at the moment spread over 2 Dell Optiplex 330s with some £20 1gb graphic cards but I'd like to move over to just the one PC, this also means that I'm used to using 4 monitors and I'd like to keep this arrangement too if possible.
My budget is £800-£1000 but that's a very hard ceiling, the wife has spoken.
I have all the peripherals and s/ware so this is for the base unit only.
So, What can you suggest?
Thanks in advance
Stuart
I would go for the Samsung 120GB EVO SSD ahead of the Kingston, its cheaper if you shop around.
I would also go for a better cooler, this one is only £15 more and its an excellent air cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-013-PT
It comes in Blue, black or red and you can get it cheaper if you shop around, im sure OCUK would price match for you.
If you are spending that sort of money then the K2 would be a better choice.
