Spec me a PCI-E 4.0 Riser Cable for the Phanteks P600S
Caporegime
12 Jul 2007
United Kingdom
Appreciate any recommendations on a certified PCI-E 4.0 cable for the Phanteks P600S.
I will be using the first PCI-E slot on an ATX board and the vertical mount slots on this case.
I assume 15cm will be enough, but what do you guys think? Also what about angles?
I want to make sure i pick the right one. :)
Running a pcie 3 riser in my evolv x you need a 90 degree 200mm or 300mm you will have trouble fitting any cards in the pci slots as it gets very tight in there had to sell my sound card .
