spec me a POE switch and super dooper AP
233
233
21 Nov 2004
Wishaw
first things first, and probably a completely stupid question i have lots of wired connections running round the house all off a bog standard 16 port switch i presume it will be fine to connect this to a POE switch?
so i need a 4/8 port POE switch and a top drawer AP that i can sit up stairs in the hallway and feed wifi to the house.
budget wise sub £300 would be great
Is it just one Poe device you need?
If you bought a Unifi AP AC Lite, it would come with a Poe injector. No need for a dedicated Poe switch.
would be good to have a proper switch to allow me to look at adding some cctv cameras down the line
