Ok, not been keeping up with the hardware side of things. I'm saving up for a new computer, albeit slowly.
My budget will be in the £250 region - looking to spend about £70 on a CPU, £120 on a motherboard, and about £60 on a graphic card. If I sell my old bits, I might even have a budget of £300 - allowing me to push my CPU and graphic card budget up by £25 each.
Basically, I just want to see what I would get now for the baseline (£250) end of my budget for now. I probably won't be buying until after Christmas, TBH.
One thing I would like to emphasise on. When I installed my graphic card (approx last year, IIRC), my average electric bill rose by about £5/month. So something I'd like to do, is build an system that consumes less power than my current system. I'll try and get the system plugged in to my power meter later.
But I do want value for money, at the same time.
The machine will be used for moderate internet browsing, MSN, Bittorrent, etc. But I do want to be able to play FEAR smoothly - something I can't do as smoothly as I'd like right now.
I won't need new drives - I have all these. Same for fans, PSU and case (case is a full tower, 6x 5.25" + 2x 3.5" bay ATX).
I'm looking to get new RAM, motherboard, CPU and graphic card. Prefer not to have onboard stuff (except USB) - or I probably just won't use it, in favour of my existing PCI cards.
If I need a new case...well, we'll come to that if I do need one. But hopefully I won't.
Thanks!
Thanks!
