120v Load Testing Summary
Similar to our recent Xigmatek NRP-MC851 review the OCZ 700W ModXStream Pro failed our 120v load testing not just once but twice with two different units. Upon attempting full load on the second unit the unit ceased to function and would only emit a high pitched whine whenever plugged in. While the unit was running however, it did have slightly better voltage regulation than expected from a group regulated design and it posted decent efficiency numbers. The unit ranged from 81.40% to 83.25% efficient with a peak exhaust temperature of 52c. While the unit failed our load test, I can't say it is as much of shock as the CWT PSH failure was since this is the first time we have seen this platform. One other interesting point is the fact that both units we received carry a test report produced by PC Power & Cooling verifying the output of these units. Given that both verified units failed our testing we have to conclude that during the verification process for units that receive the test reports from PC Power & Cooling that they are not run at 45c ambient temperature. OCZ in fact informs us that it tests at 40c, 5c lower than our testing requires. Lastly, we can draw one further conclusion from this result, this platform is not an enthusiast or industrial class platform like PC Power & Cooling lines or even OCZ's own EliteXStream or ProXStream lines.
