Spec me a powerful plug in wifi extender with long range!!
4 Feb 2004
Écosse
Hi all,
We live in a large bungalow with a sun room/conservatory at the rear and our double garage is at the opposite end of the house. We are with Now Broadband and have a Now Broadband Hub 2 as the router.
When we first moved in here, I bought two Tenda N300 plug in wifi range extenders. The one in the sun-room was primarily intended to boost the wifi signal so that if you were in the garden, you got a decent internet signal. It works pretty well.
However, the one in the garage is pretty much at the extreme edge of the signal range of the router I think (router sits in the living room and is placed pretty much in the middle of the house). All the double plug sockets are fitted on the furthest away garage wall (typical) and the router has a living room wall, utility room wall and finally a garage wall to beam the signal through. The garage extender regularly flashes orange to show a weak signal (but still just about connects although it can be flaky) and sometimes goes solid red to denote it isn't getting a signal. If you bring it inside and plug it in near to the router and then go through the link sequence again, it goes solid green - take it out to the garage and plug it in and it isn't long before it goes back to flashing orange.
The Tenda extenders were about a tenner so I'm guessing they aren't particularly powerful. What I'm looking for is a replacement plug in wifi extender for the garage which is an improvement over the Tenda N300, performance/signal strength/range wise. Speed isn't really an issue, I would simply like a stable connection in the garage, even if its not particularly rapid.
So looking for recommendations on wifi extenders, please!! :)
WiFi sadly isn’t like that. Every WiFi unit is running at the legal maximum transmit power already, and even if they weren’t you could transmit like the BBC from a huge tower antenna but your phone couldn’t transmit back hard enough to be heard because it has to run off a battery.
If you are determined to go Wireless, Netgear Orbi has genuine dedicated wireless backhaul or Ubiquiti UniFi can run in mesh mode but the real answer to your problem is a cable from one end of the house to the other and plug your Tenda into that. No more Orange light, just rock solid WiFi. Ring a local TV aerial installer and tell him you need a couple of RJ45 drops and for less than £200 you’ll sort out your issues permanently.
If you're in a bungalow
Should be relatively easy to run ethernet cable
Usually without power increase
Only way to improve is bigger antenna
Or antenna in a higher position
Or more antennas
Or directional antennas
Or better router
Looks like those tenda only have 3db antennas
If the antennas are replaceable
You might be able to improve them
Usually the isp provided router isn't the greatest either
As you are in a bungalow your best bet is to install wired access points.
Wired straight through loft should be easy.
This. I pretty much did this about 3 months ago now. Two APs in the ceiling. Cable in the loft running back to a small switch and poe injectors. Was easier for me as the 5G router is outside on the roof so the cable for that comes into the loft as well. I guess for you, you'd need to just run a cable down to the Router.
My little thread here with a diagram to help show my setup. - https://forums.overclockers.co.uk/threads/network-change-up-move-to-aps.18977913/
Only other option here would be, a mesh setup (something with dedicated backhaul channel) as mentioned. Or potentially powerline adapters (an example) and use the electric cabling in the house to transmit the signal from your Hub 2 to other areas. Being a bungalow as well should only have 1 ring main.
