spec me a powersupply
20 Mar 2015
As my pc is rebooting constantly and i think its the powersupply
I need a cheap but good one
Looking for around the £50 mark will go higher, but closer to £50 the better
as I'm still not 100% sure that it is the power supply that's broken on my pc
so dont want to spend a lot as i might need a motherboard
my current pc is
GeIL EVO Leggera 8GB DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC)
Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW)
Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard
GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (GEL38GB1600C9DC)
Be Quiet! Shadow Rock Pro SR1 CPU Cooler
MSI Radeon R9 290 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card
thanks
Click on Google.
Type power supply tester into search bar.
Look at results.
For around £10 you can get a power supply tester, and test your power supply, before spending £50 on something when you do not know what is broken.
you haven't told us what psu you are using.
the rest of your spec does not seem that old, is your psu not under warranty?
