Spec me a... Printer?
29 Dec 2009
I need a printer that's able to print to the edge of an A4 page, so I'm able to print letterheads and whatnot.
Paper size only needs to be A4
Not *too* fussed about printing speed, as long as it isn't crazily slow.
Needs to be able to print decent images too
I would prefer a wireless printer, but not too bothered if it isn't.
Needs to be able to scan too.
Needs to be ink
Budget is roughly £80.
Any recommendations are appreciated, thanks!
[As per the rules you can't link to competitor sites, so just the product model number would be sufficient :P ]
We have a HP photosmart wireless one that should be able to do all that i think we got it for about £50, only real down side is its a bit ink hungry. B110 is the model number
I have a HP printer, seems to be as you have described you want one to be. Mine is a 5515 (not sure on the letter before the number though)
