- 27 Oct 2006
- London
Think extremely low powered cpu ~ Raspberry PI (which is fairly quick)
Now what I want to do is port over an app built by me 10 years back on even slower hardware, the only thing I had going for me was memory (128meg of it), so instead of a LAMP structure I built instead a semaphore locking memcache data structure which was central to IPC from the webapp (php) and daemons (perl/php).
It worked great but roll on 10 years I want to try something new maybe JSON as my RPC transport as I want to learn something new. A 5 minute google comes up with counchbase as my best option.
What do you guys think ? and what languages do you think I should be coding in. Typically I'm thinking this...
Mobile App (HTML5/JavaScript) -> JSON -> couchbase
Server Daemon (Spec me an effecient language) -> JSON/native API -> couchbase
Web (Will probably stick with php unless everything can be client side HTML5 like the mobile app?) -> JSON -> counchbase
