I'm a freelance web developer and for the last couple of years I've been using the community edition of Feng Office to track clients/tasks/timesheets. I host it myself but its a bit clunky and missing some of the stuff you get with their paid hosted solution so I'm looking to move to a fully hosted solution. Unfortunately Feng's paid plans start at $59 a month which is too much.
So can anyone recommend an alternative hosted solution that meets the following requirements:
Someone recommended Wave Accounting. I've taken a look but think that might be slightly overkill for my needs.
So OCUKer's, what do you use that might fit the bill?
Thanks
- Needs to have a timer for recording time against tasks (needs to have manual entry as well, but timer functionality is a must)
- No storage required for documents, etc
- The ability to allow other users access to view data (not edit)
- No more than £15 per month
- Ability to report by time period/client/project/task
- It either needs to be a mobile friendly solution, or have an Android app that will allow me to update and track time when onsite with clients.
- Not essential, but preferably have the ability to generate branded invoices from timesheets (5-10 a month)
Thanks
