I've currently got a Coolermaster M520 Realpower 520W in my system which consists of the components in my sig below which is mildly overclocked. I'm running 1 x OCZ 60Gb Vertex 2E with my O/S ( W7 Home Premium ) on it plus a further 2 x 500Gb SATA drives, 4 aux case fans and a Firewire card. 1 x TPlink wireless adapter and a Logitech wireless keyboard and mouse the base station of which plugs into a USB port.
Lately with a few new games ( Max Payne 3, BF3 and Saints Row 3 ) the PC has been just shutting down randomly and restarting. It's like it does this as soon as any load is applied to it power wise. Fine doing everything else from day to day stuff like surfing the net, Word docs, using CS3 etc, it only seems to do this when attempting to play a recent game. I'm thinking my PSU isn't up to scratch and is causing the issue. As far as I know the 9800GTX+ needs a 500W PSU with 24 amps on the 12v rails. The Coolermaster does 19 amps ( I think ) on the rails so I'm underpowered from the off. I used to have an ATI 1900XT in this system and it played games ok, it's only recently that the 9800GTX+ has been tripping over when trying to run them although as far as I can recall it ran games fine when I first fitted it to my system. I was going to use Speedfan or something similar to see what the power output looks like, will do that this afternoon and report back with the findings.
So, do you reckon a new PSU would be prudent given the difference between the 19 amps and 24amps on the 12v rails?. If so, can someone recommend me a good PSU with good performance on the rails for a budget of around the £60-£70 mark?.
Thanks.
Thanks.
You have to be careful with that. The CPU also feeds off the 12V rail. 25A sound like a lot for the GPU. Seems that it is based on the PCIE max specs :
