Hi,
Moving to Canada in March and just noticed my cheap EzCool 600w psu only supports 240v input so I will need to get a new psu that will supports 100-240v
I also feel the ezcool is not performing adequately on my new setup.
Spec is as follows
AMD Phenom II X4 920 Processor (running at 1.44v)
4 x 2GB OCZ 8500+ DDR RAM (1066)
1 x 320GB maxtor sata HD
1 x DVD+/-RW (IDE) <- will be replacing this with Blu-ray/dvd-rw combo drive
1 x Radeon HD4870 1GB (powercolor)
2 x 80mm fans (blue led akasa)
1 x zalman 9700 cooler with 120mm fan
I assume 650w would be enough but I would like to have a little extra incase I decide to add more fans or whatever...
thanks.
Spec is as follows
thanks.
