Spec me... a PSU??
30 Dec 2008
Well, the title says it all (almost anyway), got a budget of ~£70, might be able to squeeze £85 but I don't want to spend more than necessary (did I spell that right??).
Will be for the spec in sig and it's descendants!!!
MUST be easy to manage cables (doesn't have to be modular, but it's preferred) Must last a few years, hopefully until the end of Nehalem (mind you we may all start having 350w PSU's again to save teh polar bears!!) and most importantly reliable. :D
I had the 750w Corsair and currently running the 620w HX & 520W VX, I have no complaints regards the cables.
Yeah 500 will be fine for your current system, you dont actually need as much as you think
Yeah actually I think there was a thread about that a few weeks ago...
I'm very tempted, but in the back of my mind, I'm just think early part of '10 (that sounds weird) with i7 and a GTX3XX/HD58XX ect. 500w might be pushing it?
Well this should give you a guide
Yeah thats full system, off of tech reports web site if you want to go check out what their system was, cant remember now tbh, saved image a few weeks ago
Thanks for that, I'll check that out...
I take it they aren't shareholders in any of the massive PSU manufacturers!!!
lol, you must be unlucky then, these are good ones but not modular
PC P&C
I'm also looking a for a new PSU for a WHS server build.
This one claims to have 15 drive connectors - can it really power 15 HDs?
(I have between 7 and 11 HDs waiting to go into my yet to be built server.)
