- 22 Mar 2009
- Cornwall
ok, in relation to a previous post here i am leaning towards the problem being PSU related.
Current Spec :
i7 950 Bloomfield
GA-X58-USB3
6 x Corsair XMS3 1600MHz 9-9-9-24 1.65v
Zotac GTX480
4x SATAII HDDs
3x 120mm Case Fans
Corsair CX600
getting random BSODs and memtest fails when multiple sticks are fitted but passes when 1 is fitted at a time. i have played with the bios to get the volts right and lowered the ram timings to try and get over the problem but to no avail. does it sound PSU related? if so, what do you recommend for the job?
Current Spec :
i7 950 Bloomfield
GA-X58-USB3
Zotac GTX480
4x SATAII HDDs
3x 120mm Case Fans
Corsair CX600
