Spec me a PSU
14 Apr 2010
Milton Keynes
Hi there,
I'm looking for the cheapest possible PSU (dont care about modular or not honestly) to run the below system
Pre OC'ed Rampage Extreme II + 950 + 6gig mem
2 x MSI Frozer GTX 470s in SlI
2 HDDs + 1 SSD
DVD-Rom
some standard case fans.
Cheap is priority!
Thanks.
You need to get your priorities right. Cheap and psu are two things that don't go together. You need a quality psu for that rig or you will be having problems.
I'm just saying i dont needs a shinney modular cables. I just need one that can handle my system.
You could get away with 750W, but I'd recommend 850W.
So, maybe a Thermatake ToughPower 775W, XFX Core 750W, Corsair TX750W. Must have 4 PCIE, and well over 700W on 12V.
I'd say XFX 850W pro core, or whichever is cheapest among these.
