Whats the difference between the one you linked and this one?
https://www.overclockers.co.uk/evga...-platinum-modular-power-supply-ca-028-ea.html
That's the Platinum version, what's the difference?
Thanks.
Thank you Danny.It's still a very good PSU and slightly more efficient, power-wise. Just a slightly older platform. Can't go much wrong with either but I'd get the newer G3 platform, personally. It looks like they've tweaked a couple of things from the previous version, plus the PSU size is smaller and will fit in more cases.
My basket at Overclockers UK:
Built by SuperFlower, designed by EVGA around SuperFlower's Leadex II platform. EVGA support is top-notch. Here's a review of the 1000W unit, which rivals the more expensive Seasonic Prime units, to get an idea: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=494
Could someone please tell me before I order this PSU.
I have 6 internal Hard Drives plus SSD system drive, BluRay and DVD writer, card reader all connected.
Is there enough connections with this PSU for all that?
Thanks again.
- SATA 9x - 6x HDD, 1x SSD, 2x Optical = 9 SATA
- FourPin Peripheral 4x - Assuming Card rearder takes 4-pin Molex or floppy connector, you're good.
- Floppy 1x
but jesus read the following review the efficiency and voltage regulation is super human on these. [URL said:
Thanks JasonM, will do.
That's a big difference in price, is the Seasonic worth that much more?
Finally, there's that amazing ripple performance. 14mV was the worst of it, and you can't take anything away for that.
And ripple? You find me the guy that says 9mV or under for all three main rails is a bad thing, and I'll smack him with a wet noodle.
Yup, forty degrees. And the unit stayed fanless roughly the same amount of time.
. It powered plenty of OC'd setups and GFX, I'm not a light PC user either. In the sense I run f@h, etc for many hours at a time. Seasonic to me have become too pricey, Super Flower really been coming up with cracking PSUs. I was all geared up to get one (a G2) back when I built my i5 4690K rig, but the Cooler Master V850 came up on a crazy promo of £85 delivered. As it was Seasonic OEM/platform, I decided to get it. Have been thoroughly impressed by it so far
