Spec me a quiet 500w-550w modular psu
28 Oct 2008
Hi, as title says I'm after a quiet PSU to power an i5 6500 and a gtx 970.
Will be in a p183/mini p180 case.
My last PSU was a be quiet unit, are these still a good quality, quiet brand or are there better options?
No budget or length limit, but must be modular.
Thanks for any advice.
If you want quiet, get something that is higher rated for what you want, along with it being gold or platinum rated.
Gold/Platinum means better efficiency, which means less heat lost, which means less 'fan on' time.
Be tempted by this...
YOUR BASKET
1 x Seasonic P Series 860w '80 Plus Platinum' Modular Power Supply £167.99
Total : £177.59 (includes shipping : £8.00 Ex.VAT).
Read the reviews: https://www.overclockers.co.uk/showproduct.php?prodid=CA-015-SS&tool=3
EVGA G2 650W would be a better option. It has hybrid fan mode and it is much cheaper.
