spec me a quiet backlit keyboard?
12 Feb 2004
Manchester
im after keyboard, it must have quiet keys and have a back light so i can see keys at night.
Uk layout with normal size enter button and normal size space bar.
oh and im not a gamer.
what you guys recommend?
cheers
try Saitek keyboard Eclipse II , got mine yesterday great keyboard with a choice of 3 colours for using in the dark and quiet
Was going to say the same, but the after looking at the OcUK Keyboard selection, all backlit ones don't have a full size return key. Unless the pics are of the US layout.
The return key on the Eclipse II covers two rows - both the Q & A rows.
I think the majority of the pictures seen are of the US version as it has only been available in the UK for....well since yesterday as far as I know :)
thanks guys, i will have a look at the Eclipse II, although it may be a bit over kill for me (average user), might go for the Eclipse (mk1) instead!
went for the Saitek Eclipse 1 in the end, didnt get the II cos it was a bit over kill for my needs.
now i just have to get used to it :)
