- 7 Jul 2009
- Newcastle/Aberdeen
Just to add to the loop, dual preferably to go on the top of my case. Bit clueless as to what's the best option for my money (preferably around £40, but a bit more if it's really worth it). It will be used in conjunction with a single rad (ask WJA if you want to know what it is). I was looking at this:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-020-BX&groupid=962&catid=1523&subcat=1525
But as i said i don't really know. Are there any review sites i should be looking at?
Also, does anybody know where i might get a mounting system for the Zalman WB3 Gold, i have the 775 bracket but i'll most likely be using AM3. Thanks
