Spec me a recordable freeview box
1 Dec 2004
S.Wales
I have about £160-£170 to spend on one, possibly looking at a DVD recordable one, with an internal HDD (If they do those?) or is it just a HDD recordable OR DVD recordable one?
Yes you can get one that will do freeview, dvd-r and hd-r but i doubt you will find one for your budget.
My recommendation would be the Humax 9200, although a little over your budget, is a brilliant box. It has dual tuners so you can record and watch different programs. As long as you leae it on the correct channel, you can actually record 2 channels at the same time, if you go out or something. Signal quality is good, picture quality is good.
It has optical out for when terrestrial channels support Dolby Digital, A large enough hard drive for a lot of recording.
If you really have to stick to your budget there is the Humax 8000 which only has one tuner, but is still a good box.
Fusion FVRT145 80Gb Twin Tuner DVR.
£125
Silver.
80Gb hard drive.
Digitally interactive.
Digital text.
RF loop.
Digital Video Broadcasting (DVB) subtitles available.
Auto setup.
Scans for new channels.
Full access to all Freeview channels.
Now and next electronic programme guide.
7 day electronic programme guide.
2 SCART sockets.
Remote control requires 2 x AAA batteries (supplied).
Size (H)4.7, (W)36, (D)24.2cm.
Weight 2.3kg.
Not top up compatible.
Had mine for a couple of months now. Totally reliable and very quiet. No lock ups at all. Can record two channels at same time and also watch a previous recording.
Im staying away from Digifusion im afraid, had numourous problems with my FVRT150 which is why i have been forced to fork out again...
Im impressed with everyones views on the 9200t especially on digitalspy.co.uk
