Spec me a router for home use
  • Thread starter Thread starter IC3
  • Start date Start date
IC3
IC3
3 Dec 2011
I'm looking at getting a new router, as Virgin SuperHub is terrible. I'm currently studying CISCO CCNA course and I was thinking of buying a CISCO router as my main. But I don't think other household users would like their wifi gone every now and then... So I might opt for something else and buy a CISCO router in the future for my own testing.
It's mainly the bad coverage that annoys me in the SH... :rolleyes:
This is my current connection..
Budget: £40-80? (I don't really want to go above £90)
what about the superhub don't you like, is it just the wifi coverage? why not disable the wifi and pickup an access point instead? you will get a lot more for your money, so to speak.
splitting up my setup at home was the best thing i have done. Router -> switch -> Access point
The SH is terrible, I found it to work better whilst its in moderm mode only with an external wireless router.
And... I want something with more features that I can play with. :p
Asus RT-N66U is within budget, brilliant router. Flash Merlin on it and you'll have more options to play around with.
Do you use this router?
I use the RT-AC68U personally but that's a lot more expensive :p. I had the RT-N56U as well (now handed down to a relative) which also works very well.
RT-N66U is one of the favourites on this forum though, very stable and good wifi range.
There's the RT-AC66U as well, but I believe that's over £90. Wireless ac will make better use of your fibre speeds though.
I was actually looking at the router you're using, but then saw the price and was like... nope.
