Spec me a Samsung Green replacement
27 Aug 2009
I just went on OCUK to look for an extra 8GB to add to my existing 8GB of Samsung Green to see its not available :(
So recommendations for replacement RAM please?
Low profile, easy to overclock.
I had my Samsung at 1866mhz, CPU is [email protected]
Samsung is now end of line.
What do you use your system for, 8gb is plenty for most tasks.
Aaah okay, thanks. About that, I'm not really sure, but I don't think they would, no. However if you ran them in a different channel I don't think they would interfere with each other, though I may be wrong?
Tbh at the most you should be looking at is 2133mhz (if so a good 9-11-10 kit) but a decent 1866 kit would also be fine and leave you some oc head room.
~2200mhz is about the best sandy bridge will do, even then it needs a super strong imc.
As for samsung ic, most 2400/2600 10-12-12 kits should be samsung (tg extreme/gskill trident x/dom plat).
