Spec me a Sander
14 Apr 2003
In a state of Flux
The Black and Decker Mouse I had before (Wife purchased) has given up the ghost so I'm looking for a new sander. I'd mainly for sanding down walls once filled, and acre's of skirting board I need to sand before painting.
Any suggestions? This Makita BO4555 gets good reviews.
http://www.screwfix.com/p/makita-bo4555-2-palm-sander-240v/85198
I have a Bosch Gop so I can use that for some of the smaller stuff like the stair bannisters etc.
You can't go wrong with anything Makita in my opinion.
Was your previous a belt sander or a palm sander? Personally I've only ever used a belt sander never used a palm sander so not quite sure how they work.
Belt sander too vicious, better off with a Ramdom orbital sander.
Your budget?
I alway like Makita, expensive, but they last, my makita sanders must be nearly 15 years old, & well used.
This would be my choice, & use quidco will knock a few more pounds off the price.
Random Orbit Sander 5".
http://www.amazon.co.uk/Makita-BO5030-Random-Orbit-Sander/dp/B001KYJ2Z4
Makita 1/3 sheet sander Makita BO3711.
http://www.amazon.co.uk/Makita-BO3711-3-inch-Orbital-Sander/dp/B002WU79PU
There is Bosch their green (DIY) range, similar price, BUT no where the quailty of the Makita.
Forget Erbauer, the number of there tools I see being return, when I'm in the local Screwfix here never cease to amaze me.
Eh depends what your sanding ;)
The DeWalt looks pretty impressive and has very good reviews only negatives about it are the dust bag isn't very good. However I wouldn't let it stop you buying it.
Think Dewalt is usually a 1 year warranty. In all honesty I have never had any decent power tool fail within a year. Usually way past 3 years for any of my Dewalt or Makita gear and they get used and abused daily.
Some of the latest Dewalt tools are 3 year warranty. There is an impact driver I am currently looking at getting on their new lithium battery system, which is 3 years warranty.
http://www.ebay.co.uk/itm/BRAND-NEW...Home_Garden_PowerTools_SM&hash=item4610e2babf
Think this is the same model for £79.99.
