spec me a screen
12 Dec 2004
the south
Hay all
I'm off to the south of France for a week next month and will be covering around 2000 miles.
I did this trip last year on my gsxr which had adjustable clip-ons and rear sets so I set them as comfortable as possible.
This year I'm on my 08 r6 which is standard and being 6 foot its not the most comfortable bike in the world.
One of the main things is wind blast. getting down there we use toll roads and we don't hang about so the constant wind blast gets annoying.
Not sure if such a thing exists but I'm after a screen which can attach to the current screen to add a bit more protection but it must be able to attached/detach easily.
Any one know of such a thing?
cheers.
cheers for that its just the kind of thing I'm after.
Would be ideal if it was a UK based company.
Sorry should have said I already have a double bubble screen, while its an improvement over the original i'm after something more.
Don't give too hoots what it looks like i'll only be using it for the trip down and back, for the rest of the week i'll take it off.
ahh,have you looked on busters? or m&p they have some touring screens and airflow screens you would need to check if they fit your bike
famas, all I did was google 'Laminar Lip R6' and posted the first link, I am sure you would find a UK based supplier if you spent longer than the 10 seconds I did :D
