I was planning on doing both to get a clean join and a 10mm expansion gap under the frame.Can't you just use a jigsaw for that?
Alternatively pick up a multi tool and trim the door frames so you can fit the flooring under the frame. Always looks much better that way.
Chers but no longer available. Anyway when I last saw it it wasn't available online or near me.Machine Mart have a 16" scroll saw for £60 which is pretty cheap. There stuff is ok not great but robust enough in my experience.
Cutting a few curvy bits in engineered wood flooring to fit around door frames.
Andi.
Yes that is it. A scroll saw is just a powered coping saw anyway and a variety of blades are available. They also keep the blade straighter than I ever could.That's it?
Buy a coping saw and a jigsaw. Jigsaw for the easy bits. Coping saw for the fiddly bits. Even better if you can get some spiral blades for the coping saw. Cut in any direction then.
