Spec me a set of Carb Sync Gauges/Balancing Tool
22 Aug 2010
On the Wagon-East Angular
I want to balance the carbs on my bike, so need to buy a set of gauges. I need 4 gauges/dials. What sort of thing should I be looking at? Something cheap and cheerful that'll get the job done, or is it worth paying more for a "better" one? Also, digital or analogue?
Ta muchly!
Morgan Carbtune Pros seem to be the ones to go for if your ok paying a bit more than the cheap Amazon dial type ones .
FYI - I've only done balancing 3 times and dont have any experience of any other products than the Carbtune ...
I bought the "cheap" eBay ones and they failed after exactly three minutes and the seller never processed the refund.
Ended up using a pull through type SK Synchrometer - but sounds like that won't work for your situation
Ta muchly!
Did you get some? I have a 4cyl set you can have for postage only.
