Spec me a small brush
17 Oct 2006
Bristol
Hello everyone,
I am looking for a small brush and a place to buy the small brush from. I need it to clean my shaver and my beard trimmer. I had an alright small one that was suited to the task that came with the beard trimmer but I've misplaced it. I'm quite particular about keeping them clean and it does help them work better if they're not all jammed with hair.
Thanks.
Mm that's a good idea actually but it wouldn't be able to fit deep enough into my beard trimmer to clean the bottom of it as the bristles are facing the wrong way :(
Boom Boom!
