Actually, you can do this in stead, forgot the Mobo has 1080p and HDMI support
The mobo has the firewire, USB, and ethernet bells n whistles
Code:
- LGA 775
- ATI® RX1250
- ATI® RX700
- FSB1066
- HDMI™ 1080P
- PCI-E X16
- Dual DDR2-800
- Gigabit Ethernet
- 7.1 CH HD Audio
- SATA 3G RAID
- RoHS Compliancy
Righteeeooo.
Here is a revised spec, with reasons to follow
As said before, no need for the GFX card, that motherboard will do just fine with your visual needs.
I went with the Hauppage 1300 in stead, as it is the Media centre edition, get the remote with, and I have been using it now for a long time and it's a great tuner card, my freeview reception is impecable.
I specced a USB card reader, because you cannot fit an internal one into that case. Yes the case is a tad more expensive than it's cheaper older brother (in which an internal card reader wil fit), but it really oozes quality and is super silent + a cool programmable VFD.
If you want the case to be even more silent, get a 3rd party cooler for your CPU, something like an arctic freezer of summit, tis what I have in mine.
For an HTPC, this spec is quite a mean machine, some might say it's overkill, BUT if you will be doing recording, channel hopping...decoding etc, this baby will breeze through it.
I didn't include an OS, as you have not mentioned it.
Personally, i would just use XP pro if you have it already, and stick on a open source front end for your HTPC needs. I'm quite an avid fan of Media-Portal, which can be downloaded at
www.team-mediaportal.com. It is a tad more fiddly to set up according to people who prefer MCE over it, but it feels much more natural to me, much easier to set-up with loads of user-requested functionality.
