Spec me a small PC with superb single core performance. Graphics not important.
Commissario
16 Oct 2002
In the radio shack
I'm looking for a super small PC with the fastest possible single core performance using an Intel CPU.
Graphics performance is simply irrelevant because it won't have a monitor attached, I'll be using it headless for an application that doesn't really use the graphics card.
It needs 32Gb memory and a decent speed nvme. Someone has said it should have a Z790 chipset motherboard but that means nothing to me.
As quiet as possible. Ideally it'll be small enough to sit on top of my radio but that's probably not possible.
I know nothing of modern PC specs and I have no parts whatsoever so it's over to you, the knowledgable OcUK members :)
What do you suggest?
budget?
will you want to overclock to get the max single core perf?
how many cores do you need or just a single core is enough?
It costs what it costs, I don't have a specific budget but that doesn't mean that the sky is the limit. I really have zero idea what pc components cost these days because I haven't bought anything since around the time that Vista came out.
Not really, no.
realistically you'd be looking at a 13600k for best price/performance without breaking the bank
if you're willing to sacrifice a bit more performance then the 13100 is better value because you can save more on the mobo etc as well
Thanks - I can look at the spec but I have no idea what individual components I need to put together to build a PC.
I mean, I know I need a PSU, case, motherboard, memory, cpu and nvme but it has literally been fifteen years since I built one.
If the aim is small and quiet, Optiplex and Thinkcentres both come in ultra small form factors and can be specced/upgraded to hit your CPU/RAM requirements for not a huge pile of notes...
Actually @dymetrie, that's a really valid point. A little Dell Optiplex has an i5-13500T which is only 12% slower in single core mode than the i5-13600k that @tamzzy has mentioned and only 2% or slower than the i3-13100.
But still looking for peak performance, would an i7-13700k go in there?
Yes it will, as would an i9-13900KS
