Spec me a small, silent build for light gaming
5 Jun 2007
extremes.spacious.indelible
Hey all,
Currently have a build from about 4 years ago that's noisier than a 747 and draws all of the power.
Moving house so want something smaller and quieter, preferably to sit next to/under the TV.
Not looking for running newest games in Ultra settings, but things like planet coaster, prison tycoon, games that require a bit of grunt but nothing serious.
Budget, £500?
Cheers :)
Why have you got 2 psu's ?
Why would you spend almost £140 on a motherboard with a £500 budget ?
SSHD's are a waste of cash. Might as well just go with a regular hard drive.
It will bust your budget - and then some - but look at the Streacom DB4 for added spousal approval.
My basket at Overclockers UK:
Total: £937.54
(includes shipping: £11.70)
You could also use a GTX 1060.
How hot do you think a pentium is going to run to warrant a £250 case and £120 psu ?
A HTPC case, low profile cooler and an SFX psu would do the same thing for way less.
Total: £504.14
(includes shipping: £12.30)
This is based on what is in stock (there aren't may HTPC cases in the lower price bracket that are in stock, so I went for a standard micro ATX case), and I added a CPU cooler since stock coolers don't know the meaning of silence (plus they suck).
