Spec me a spacious case
21 Oct 2005
Edinburgh
Budget - £65
Task - To spec me a spacious case in which to house the below "rig".
I have.. 4 HD's currently contending with an X1900XT and a big typhoon, its carnage, and a nightmare to work on. Any suggestions? :cool:
Chieftec Dragon case.
Acres of space for Hard Drives and the 1900 if you get the full tower version, and comes in under budget. :)
Akasa eclipse but it is out of your budget, Antec P180 can be had for £70...
Maybe a full tower Chieftec or an Antec Plusview 2 (seen for £51)
Edit: Beaten by miles as I looked for Plusview pricing :(
Coolermaster Ammo, about £50 + Delivery and £10 for the Rear 120MM fan, has side air vents to bring fresh air into your typhoon...front vent with 120MM fan to cool hard drives "Holds 4", rear 120MM fan mount, and Top Air vent....
Specs
Available Color: Black
Dimensions: 485 x 215 x 460 mm
Material: Plastic front bezel; SECC chassis; Aluminum details
Weight: 10kg
M/B Type: ATX 12” x 9.6” (30.5cm x 24.5cm); Micro-ATX
5.25” Drive Bay: 5 (Exposed)
3.25” Drive Bay: 1 (Exposed); 4 (Hidden)
Cooling System: One 120x120x25mm front fan 1200rpm, 22dBA (Intake)
Support 12cm , 9cm and 8cm rear fan (Exhaust)(Option)
I/O Panel: USB 2.0 x 2, IEEE1394 x 1, MIC x 1, *** x 1
Power Supply Standard: ATX PS2(Option)
http://www.newegg.com/Product/Product.asp?Item=N82E16811119098
Also looks like a 5 year old designed it and is no bigger than his current case :p
Edit: In fact it only has 3 spaces for HDs (and 2 external ones that could be used) and is a little bit smaller.
meansizzler - I know that they dont ship to the UK, but I would still class that place you mention as a competitor - I would remove the link if were you.
PC7 would work just fine but it isnt really any bigger and cooling wont be much better at all. Any others are out of your budget.
Yeh got a similar system in a PC7+, quite good temperatures but the HDD's will need either a hard drive bay extender or stick one of them in the floppy bays.
Still WIP but you can see there is a fair bit of space in the Dragon
Yeah theres nothing wrong with it and it would hadle the HDs/graphics fine cooling wise, but the OP wants a more spacious case and it really isnt much bigger than what he has.
Ahh I didnt notice the sig, ignore that suggestion and stick with the Dragon one. :)
Only posted the link cause tht place has the best pictures for cases..not intended as a competitor...not everything is about money you know..jsut trying to help a guy out
Yes and he is trying to stop you getting suspended. Newegg are not a competitor but posting them for such things is frowned upon, better to rehost the pictures.
