Spec me a surge protector
16 Mar 2012
Hove
Better to be safe than sorry :D
No idea if any will do the job, best to ask i thought... i don't need that many ports, maybe need to plug in 5 items (2 monitors, sound, pc + 1 i swap, could get it down to 4 though), and have 2 wall sockets available.
I bring that up because i've always wondered whether it's smart to put a lot of equip into one of these..
Better to chuck it all in the surge protector and have it be safe than in the mains and possibly blow up really. As long as you're not running another extention lead from it, I don't see the problem.
I use a Belkin one (cant remember the model) I've never experienced any issues (either because theres never been a power surge to test it, or it has done its job without me knowing)
Fit and forget at its best.
While there is a thread on surge protectors, would these protect the lines from a lightning strike and would you be covered by the protectors insurance?
Ok just ordered this:
So you actually believe the little 2 cm part inside that box will protect when even three kilometers of sky could not stop it?
Read the specifications. It does not even claim to protect from a typically destructive surge. Destructive surges can be hundreds of thousands of joules. How many joules will a Belkin absorb? Even the warranty contains numerous exemptions so that it need not be honored.
It only claims to protect from surges that typically cause no damage. For less money per protected appliance, install what even BT uses. Because BT computers must work during every thunderstorm and never suffer surge damage.
These things must work or people wouldn't make them. Also your hate of UPS and the battery mode, you say that's dirty. Yeah it might be dirty power when the UPS run on battery mode, but its only running on batt mode a few mins in a year during power loss or a storm. So yeah I would prefer my pc using durty power then being constantly on the mains with zero protection during a storm or powerloss.
