Turbulance said:
Thanks for all the replys and I have been saving up a bit more.
edit* question- how does the Opteron stated here compare to the Dual core 4400+? Is it worth spending the extra money on the 4400+?
edit* would it also be worth considering a crossfire motherboard so I can slap another x1900 in there ina few weeks time?
Also I am looking to do a bit of overclocking
Opty's are basically re-branded FX-60 cores, originally designed for servers. They run cooler and use less power than std chips and tend to be more stable. They also overclock better than the std X2 cores.
As far as the crossfire thing goes, IMO no. 2 gfx cards are a waste of money! Save your cash and just upgrade the card to new tech every 9-12 months. That way you'll always be able to play the latest games as they were designed to be played.
Here's my suggestion, semi-pro's with a few minor tweaks. With future proofing in mind I would go for a more powerful PSU cos I think you may need it by this time next year:
CP-148-AM AMD Opteron UP 170 Dual Core San Diego 2.0GHz 2MB Cache (Socket 939) - Retail (CP-148-AM)
£274.95 £274.95
FG-000-AR Arctic Cooling Freezer 64 Pro CPU Cooler (Socket 754/939/940) (FG-000-AR)
£15.95 £15.95
MB-014-DF DFI LanParty UT NF4 Ultra-D (Socket 939) PCI-Express Motherboard (MB-014-DF)
£79.95 £79.95
MY-057-OC OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series EL-DDR CAS2 (OCZ4002048ELDCPE-K) (MY-057-OC)
£139.95 £139.95
HD-002-HI Hitachi Deskstar T7K250 NCQ 250GB SATA-II 8MB Cache - OEM (0A31636) (HD-002-HI)
£56.50 £56.50
CD-026-NE NEC ND4551 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Black) - OEM (CD-026-NE)
£25.95 £25.95
CA-017-TT Thermaltake VB1000BNS Soprano SuperMidi Tower - Black (CA-017-TT)
£39.95 £39.95
CA-008-TG Tagan TG530-U15 530W ATX2.01 Easycon SLi Compliant Modular Silent PSU (CA-008-TG)
£59.95 £59.95
GX-047-HT HIS Excalibur ATI Radeon X1900 XT-X 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-047-HT)
£304.95 £304.95
Subtotal £998.10
VAT £174.67
Total £1,172.77
