Hi all. First time poster here.
I am looking to build my first gaming rig. I have previously performed upgrades on normal pcs and have confidence enough to build my own using the guides on here. Currently have a PS3 and XBox360 but a few friends have talked me into the pc gaming idea when I said about getting a set up for the movies and photos.
I will be running it in my lounge on this HDTV http://m.lg.com/uk/tv-audio-video/televisions/LG-3d-tv-47LW650T.jsp
My room is 18 feet long and distance will be about 14feet between me and tv.
I would like it to be as good as possible for as long as possible without upgrading for a few years at least. But in 2 or 3 years I would like to have the option to upgrade it a reasonable amount.
I use my current computer although slow for photo and some video editing. I also would like a reasonable sized SSD (256Gb-512Gb) for program's and a large HDD for downloading and storage of movies. I would also like to be able to play any games I so choose for a few years without problems.
I will be in USA in 4 weeks and found a store where I will be that has the 3930 and ASUS Rampage IV Extreme for £650 total. Which I was thinking to get when I'm there. Probably overkill but the saving helps make up for it. The 3960 is £280 more though both chips might drop in price a bit by the time I go.
I see the Samsung green Ram gets good reviews here so will probably add that too.
Anyways, I would like you to spec me the rest of the set up.
I would buy the 4GB Evga 680 if I thought it was going to be good enough for a long time. Plus some bragging rights to the lads lol.
I have £1750 to £2000 to spend on the rest of the set up. Although you don't need to spend the whole amount if you feel it's too much. However I would like to not need to spend anymore for anything else for as long as possible preferably 3 but hopefully 4-5 years if possible.
The reason being I have the funds now but with kids and house the funds to upgrade annually or every 2 years may not be possible.
Thanks
Phil
Thanks
Phil
lol!
