Spec me a system to beat my current lot
23 Aug 2005
Cheadle, Cheshire
Hi all
Due to my PSU shorting and causing a fire (yes that's right a fire!) and burning the HD's to within an inch of there life (I have yet to test them TBH), i would like to renew a few of my components.
Currently
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard
Corsair XMS3 DD3 (2 x 8GB)
Asus GeForce GTX 560Ti DirectCU II 1024MB GDDR5 PCI-Express Graphics Card
With a budget of around £500-£600 and only sporadic gaming (Football Manager, BF etc.) can you recommend some components which will improve the above.
Regards
Lee
After reading further - I think my rig is still fine but just needs to OC the CPU (I have the Arctic 7 Cooler) and then get a better GPU?
You are quite right - the 2500k is still fine. Which case do you have? Just to make sure everything will fit.
Do you have an SSD?
