Spec me a system upgrade :)
23 Jul 2009
Bath
Having finally got a decent gfx card (5850) I'm looking to build a new rig to complement it, as I'm starting to outgrow my current rig.
All I need is CPU, RAM, Mobo and a decent cooler. I'll be getting a new case (got my eye on the NZXT phantom, despite what you all say!) so space isn't an issue. Budget, however, is.
I'm torn between i5, i7, and the 1055T for the CPU. The AMD option looks like good value, but having always been with intel I don't know how easy they are to OC or any other details I should know about. I just want something that will last me a good few years without bottlenecking any gfx upgrades I might pick up along the way.
Motherboard needs to be a good clocker, and leave room for xfire/sli, but beyond that anything will do. Stability is the key factor for me here
RAM: if it works and doesn't hinder overclocking, then anything is fine. 4GB should be more than enough for my uses.
Budget: would like to keep it under £400 if possible (not including case), but will stretch a bit if it's worth it.
This is what I came up with so far (comes to £404 without case)
Mainly, because I'm clueless with regards to what AMD boards are like (or CPUs for that matter) I'd like to see how it compares and if it would be a good value for money option. Cheers peeps :)
That case is not rated in my book, how about one of the cases from Silverstone, or Antec? An Antec 300 is over half that price and looks ok, and it would match your CPU cooler :) (Both black).
Also what about storage?
this amd motherboard does crossfire
www.overclockers.co.uk/showproduct.php?prodid=MB-251-GI&groupid=701&catid=5&subcat=1782
so add a CPU of your choice, and the other parts in your list.
Do you reckon it'd be worthwhile for me to go AMD though? I'm really torn between going for an i5/i7 or whether to go for a hex core AMD, but I don't know enough about the AMD CPUs in terms of clockability, reliability etc.
For pretty much the same price I could get this
Which would you choose? I know I could overclock the i5, but what are the 1055T's like for overclocking/heat output/etc?
If the rig you are upgrading is the one in your siggy then i really would'nt bother at the moment. 1156 will be dead by the end of the year and it is unclear whether AMD's new cpu's will work in a AM3 board. A E8400 at 4.5Ghz really is'nt going to struggle in much for a while yet.
I'll swap ya? :p There are a few apps/games I've noticed that I'm cpu-limited in. Most obvious is BC2 where my GPU never goes over 80% usage because my cpu is holding it back. It's mainly just the itch to upgrade, but perhaps I'd be smart to wait until Sandybridge and bulldozer are out before making a decision. Damn you reason!
