Spec me a system (without monitor) for £1000
8 Feb 2006
I'll use it to play games mainly, I need as much memory as I can get in the price. I see OC sells memory in 6gb lots, what OS will address this much?
I probably won't overclock anything, but the option would be nice.
What size of monitor do you plan on using? Also for gaming, you won't need anymore than 6gb in triple channel (if going for i7), or 4gb dual channel going for phenom II.
I'd definitely consider overclocking, especially if it's for gaming. You'll see the biggest benefit coming from an overclocked CPU.
If it is purely for gaming, then you could save your money and go with an AM3 setup, will be on par performance wise as the i7, but cost a bit less. Obviously the i7 is a better chip when other factors come into play, but for gaming both are roughly the same.
Thanks, looks like I've been out the loop for a long time, I should do some reading. I'd say it's 99% for gaming, the rest just some general excel/word stuff.
I realy need 6gb, is this intel chipset specific?
I have a 24" monitor, I'm toying with the idea of a 30".
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.20GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle + World in Conflict Game *OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.20GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle + World in Conflict Game £569.99
(£495.64) £569.99
(£495.64)
Options applied to the above product:
4.00GHz Overclock £17.24
(£14.99) £17.24
(£14.99)
XFX ATI Radeon HD 4890 XT 1024MB GDDR5 PCI-Express Graphics Card (Includes Tom Clancy's H.A.W.X.) XFX ATI Radeon HD 4890 XT 1024MB GDDR5 PCI-Express Graphics Card (Includes Tom Clancy's H.A.W.X.) £154.99
(£134.77) £154.99
(£134.77)
Corsair HX 620W ATX Modular SLI Compliant Power Supply (CMPSU-620HXUK) Corsair HX 620W ATX Modular SLI Compliant Power Supply (CMPSU-620HXUK) £94.99
(£82.60) £94.99
(£82.60)
Western Digital Caviar Green 1TB SATA-II 32MB Cache - OEM (WD10EADS) Western Digital Caviar Green 1TB SATA-II 32MB Cache - OEM (WD10EADS) £61.99
(£53.90) £61.99
(£53.90)
Pioneer DVR-217FBK 22x DVD±RW SATA Dual Layer LabelFlash ReWriter (Black) - OEM Pioneer DVR-217FBK 22x DVD±RW SATA Dual Layer LabelFlash ReWriter (Black) - OEM £17.99
(£15.64) £17.99
(£15.64)
Sub Total : £797.54
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.00
VAT is being charged at 15% VAT : £121.13
Total : £928.67
You can always buy another 4890 later or strait away if you feel its needed.. what res u play at?
1x hd4890 or gtx275 (both v similer in performance) would be sufficient but you always have the option for sli/xfire later on
