spec me a system
20 Jul 2007
gloucestershire
missus has 400 pounds to spend need
cpu
mobo
gfx
ram
hdd
she plays a few games only sims really but wants a really quick o/s cheers kris
£400 goes a long way these days:-
Intel Core 2 Duo E2160 "LGA775 Conroe" 1.80GHz (800FSB) - Retail
(£52.86)
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
(£176.24)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC)
(£46.99)
Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard
(£76.36)
Hitachi Deskstar T7K500 250GB SATA-II 8MB Cache - OEM (0A33423)
(£39.94)
Total : £402.91
(£52.86)
OcUK ATI Radeon X1950 Pro 256MB GDDR3 HDTV/DVI (PCI-Express) - Retail
(£70.49)
Corsair HX 520W ATX2.2 Modular SLI Compliant PSU (CMPSU-520HXUK)
(£68.14)
(£46.99)
(£76.36)
(£39.94)
Total : £365.30
cheers looks good are is that processor quick ? or is it worth going for somthing like say the e6750 or e6550?
All the conroes clock to at least around 3 GHz, including the e2160. With the e6550 and e6750, you're paying intel to do the clocking for you.
It's quick enough for what she wants it for, good enough for SIMS / other light gaming and quick enough to not slow down an OS.
[EDIT]: I'd go with the suggested graphics card from melbourne instead of the 8600 GT also, you loose DX10 (oh noes!) but the X1950 is more powerful and exactly the same price.
Product Name Qty Price Line Total
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £39.99
(£46.99) £39.99
(£46.99)
Asus GeForce EN7600GS Silent HTD 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £39.99
(£46.99) £39.99
(£46.99)
Hitachi Deskstar T7K500 250GB SATA-II 8MB Cache - OEM (0A33423) £33.99
(£39.94) £33.99
(£39.94)
OcUK Huntkey 450W PSU £27.99
(£32.89) £27.99
(£32.89)
Intel Core 2 Duo E6750 "LGA775 Conroe" 2.66GHz (1333FSB) - Retail £106.99
(£125.71) £106.99
(£125.71)
Asus P5K SE Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £64.99
(£76.36) £64.99
(£76.36)
Microsoft Windows XP Home Edition inc. SP2 - OEM - 1Pk (N09-01528) £47.99
(£56.39) £47.99
(£56.39)
Sub Total : £361.93
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £64.90
Total : £435.78
short answer: no
long answer: no, you've overspent on the cpu, and under spent on the GPU and PSU.
It'll do letters/internet/very old games, but then so will a £299 laptop, and that comes with a free screen :D
OcUK GeForce 8500 GT 256MB DDR2 HDTV/DVI (PCI-Express) - Retail £39.99
(£46.99) £39.99
(£46.99)
Intel Core 2 Duo E6550 "LGA775 Conroe" 2.33GHz (1333FSB) - Retail £94.99
(£111.61) £94.99
(£111.61)
(£76.36) £64.99
(£76.36)
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £38.99
(£45.81) £38.99
(£45.81)
(£56.39) £47.99
(£56.39)
Corsair VX 450W ATX PSU (CMPSU-450VXUK) £39.99
(£46.99) £39.99
(£46.99)
Samsung SpinPoint S 160GB SATA-II 8MB Cache - OEM (HD161HJ) £28.99
(£34.06) £28.99
(£34.06)
Sub Total : £355.93
(This can be changed during checkout) Shipping : £9.95
VAT is being charged at 17.5% VAT : £64.03
Total : £429.91
I'm not sure if the E6550 is a good choice in general, and for the graphics, you could get better for the money.
hey there, i had a look at the spec you had and tried to get more value for money.
the Cpu is way better for exactly the same price, and i changed the PSU because asaka have almost silent psu's and with that spec i don't think you'll need over 400w at all.
I added the 8600 gt because it has GDDR2 instead of DDR memory which will run your games a lot faster and smoother and performs better than the 8500 GT.
the rest is just what i think will work well
by the way you can add a home vista o/s instead of your windows xp home:
http://www.overclockers.co.uk/showproduct.php?prodid=SW-034-MS&groupid=33&catid=20&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=OS-001-MS&groupid=33&catid=20&subcat=
they are both the same price, you can choose whichever you like.
good luck! ;)
