Yes, that's right, a tap!!
Basically I'm in need of a new kitchen tap as the current one is cheap, nasty and leaking!
The missus would like one of those fancy one's where it has a regular spout but also a pull-down flexible hose-type head for rinsing round!
I've seen some at £150+ and some at £50ish that look pretty much the same!?!?
Can anyone recommend a reliable online supplier as the likes of Wickes & B&Q etc seem to be on the high side cost-wise?
Thanks...
Thanks...
