Spec me a tenless brown key
9 Dec 2007
Hants
Seems like my Corsair K60 has bitten the bullet this morning (USB device not recognised and keeps making the USB connect disconnect sound over and over).
Wanting to get a tenless mx/gateron brown board. Not bothered by LED backlighting.
Like the Ducky One TKL but can't find anywhere with stock and/or in the UK.
Any suggestions?
I would recommend Ducky/Filco or similar boards, I have a Keycool hero 84 which is technically a 75% board, and a Leopold FC660M which is a 60%, but they both retain the
arrow keys.
Just to aid your search a little and maybe avoid confusion, the term is "tenkeyless" or TKL for short, and the colour refers to switches not the keys!
Highly recommend the Ducky Shine TKL keyboards, very solid. I have an older Shine II TKL with black switches. I believe the Shine III comes with brown as an option?
Well any ducky tkl is proving a nightmare to find stock. Only mx black or white available.
Ocuk have COOLER MASTER MASTERKEYS PRO S RGB LED MECHANICAL GAMING KEYBOARD - CHERRY BROWN Switches. Bit more than I was hoping to spend but a good board?
Yeah i just noticed they're pretty difficult to find with that combination! Well, if i were to go with any of the more gaming oriented brands offering mechs then i think i'd probably go with CM. Just do a fair bit of searching for reviews on the board. Here's one to get you started!
